[Deleted]
Old Jul 16, 2003 | 10:39 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Jul 17, 2003 | 12:30 AM
Firestarter1984's Avatar
Default WONT START!! 911
Once my ECU went crazy and started just revving out of nowhere when i started the car, but i was able to start the car though. I just shut it off and started again and it stopped.</P>
Old Jul 17, 2003 | 01:18 AM
Default [Deleted]
[Deleted by Admins]
Old Jul 17, 2003 | 01:28 PM
brrman's Avatar
My sunroof used to act up on its own, but it hasn;t done it in a while. I did replace my ecu when Ichipped, so maybe it was indeed the ecu.</P>
Your car does have an "idle control valve", but usually a bad one of those means you idle way too low. A bad coolant temp sensor would keep your car from starting, but should not affect idle. A bad fuel pump/filter might be the cause. A plugged filter could cause surging.</P>
Don't have access to a VAG?</P>
http://www.steve-hall.com/cgi-bin/VAG-Locator.pl</P>
</P>
Old Jul 17, 2003 | 09:15 PM
Default [Deleted]
[Deleted by Admins]
Old Jul 18, 2003 | 01:29 PM
brrman's Avatar
Yeah, hot oil on your sensor would make it act a little crazy.I had to replace my coolant sensor last month - I had to crank my car like 20 times before it would start. </P>
Hopefully your problem is solved!</P>
Deleted User
Feb 27, 2004 08:42 PM
Deleted User
Jan 27, 2004 12:58 AM
Deleted User
Oct 23, 2003 03:37 PM
Deleted User
Sep 22, 2003 09:08 AM
Deleted User
Sep 21, 2003 02:30 PM
