[Deleted]
Old Sep 2, 2003 | 08:09 AM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Sep 2, 2003 | 01:21 PM
brrman's Avatar
Default 1.8T EngineNoise
Could be water pump. I would also check your timing belt tensioner. It could be failing or may have already failed - causing the belt to slap around. That happened to me - the car sounded like a diesel engine, but when I hit higher rpm it went away. In any case - this is BAD and if the belt slips off or shreds, your engine is in for a rebuild. If the water pump fails - the belt will also slip or break, so either way you need to get this checked as soon as possible.</P>
Another possibility is the heat shield near the airbox is rattling off something.</P>
By the way - is it a 1.8t or a 2.8?</P>
Deleted User
Feb 27, 2004 08:42 PM
Deleted User
Jan 27, 2004 12:58 AM
Deleted User
Oct 23, 2003 03:37 PM
Deleted User
Sep 22, 2003 09:08 AM
Deleted User
Sep 21, 2003 02:30 PM
