[Deleted]
Old Oct 24, 2003 | 03:54 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Oct 24, 2003 | 08:07 PM
brrman's Avatar
Default Crazy Brake Problem
Master Cylinder could be the problem - maybe pressure is slowly being lost after you have been parked. And after 20 minutes or so it has built back up so that the pedal works more normally.
Just a guess though - I am not all that knowledgable on brakes.
Old Oct 25, 2003 | 06:02 AM
SlimChriz's Avatar
Im not that good at brakes either but i had a vacuum line that i had broken when fixing something else so i replaced them with new ones but i got one of the check valves in the wrong way and the brakes acted real funky </P>
There should be a diagram for the vac lines at the top drivers side under the hood try checkin them maybe youl get lucky and itl be somthin stupid(cheap) I dunno</P>
Old Oct 25, 2003 | 12:22 PM
Default [Deleted]
[Deleted by Admins]
Old Nov 15, 2003 | 11:13 AM
Default [Deleted]
[Deleted by Admins]
Old Nov 16, 2003 | 04:37 AM
SlimChriz's Avatar
Make sure if you have any occurance of a squishy pedal to take it back and have em bleed it again </P>
my last car i had brake work done on it and the next day it felt like i was steppin on a tomato every time i stepped on the brakes. turns out there was a rouge air bubble lodge somewhere We bled them three times and finaly got it out. </P>
$190's not that bad guess it could have been worse huh?</P>
Old Nov 20, 2003 | 11:03 AM
Default [Deleted]
[Deleted by Admins]
Old Nov 20, 2003 | 12:11 PM
brrman's Avatar
I know I love those wheels, Pete...
Old Nov 21, 2003 | 01:34 AM
SlimChriz's Avatar
Yeah there pretty sick huh. what year is it? what size tires you got on there they look big?
Old Nov 21, 2003 | 04:26 AM
brrman's Avatar
well, its got small sidemarkers which makes it at least a '99 and below I'm guessing. Id have to see the inside to tell more.
But dayum those wheels are tight.
