0-60 WTF?! and Turbo… working or not?
Old Feb 14, 2007 | 02:24 PM
wood_e's Avatar
Default RE: 0-60 WTF?! and Turbo… working or not?
lol... my 12v does it in about 9-10 seconds....
Old Feb 14, 2007 | 02:30 PM
kriptonik's Avatar
11 seconds sounds so slow.
I think my B5 does it faster than 11 seconds.
Old Feb 14, 2007 | 02:34 PM
onepoint8tee's Avatar
turbo lag is not an issue with the k03. It starts to spool very early at about 2k rpms and hits full boost around 3k-3500rpms. If you know how a turbo operates, you cant ask for much more than that as far as minimal lag goes. That doesnt mean your car isnt slow though. Panda is right, your car is heavy and you only have 170hp. Plus you have automatic which means you cant launch, or bump the rpm's up to spool the turbo a little bit before you get going. On top of all that, you are DBW which is gunna give a slight delay in throtle response, which is most noticeable when going from a stop. Thats just how it is with a heavy, automatic, stock tuned/under tuned, DBW car. Get a chip.
Please dont start another thread on the same subject which you have already addressed in this thread.
Old Feb 14, 2007 | 03:03 PM
NuYorka103185's Avatar
I have heard of people holding the brake and hitting the gas lightly up to about 2500rpm then letting go of the brake and flooring it. I tried it once or twice. I never timed it. It didn't feel like I hit 60 faster but the car jumping sure did hurt my damn neck.
Old Feb 14, 2007 | 03:05 PM
tractioncontrol's Avatar
When professional drivers test 0-60 times in an automatic they brake boost the car. Try holding the brkes down as hard as possibleand hold the accelerator down enough to raise the rpms without the car inching forward and launch by letting off the brakes and punching the accelerator at the same time. This will raise the rpms giving you boost off the line.
Old Feb 14, 2007 | 03:13 PM
ORIGINAL: tractioncontrol
eh... That will work, but dont get into the habit of doing it. Its not exaclty doing great things for your flex plate/tq converter when doing that. Not worth it imo
Old Feb 14, 2007 | 03:41 PM
ORIGINAL: onepoint8tee
^^^^^^^Agreed ^^^^^^^
Old Feb 14, 2007 | 04:36 PM
  #18
jlinaschke's Avatar
showing newness here… OK I looked it up and K03 is the turbo model, got it. But what's DBW?
The other thread I suggested was discussing the difference between D and S automatic modes. So as requested, I won't ;-) So then… my understanding is the S mode revs higher before shifting. Does it do anything else, like downshift more aggressively? If I'm taking a windy-road tour, should I be in S mode? And WHY would the car get inferior 0-60 in S mode? This just seems bizarre to me.
Chip… yes… keep hearing that LOL. I'll do due diligence and research it before asking any dumb questions here. THEN I'll ask dumb questions ;-)
thanks again
-Joseph
Old Feb 14, 2007 | 04:49 PM
  #19
swift_A4's Avatar
don't worry about your 0-60 time your not driving a honda, and i bet you are comfortable.
Old Feb 14, 2007 | 04:54 PM
  #20
DBW is drive by wire. It is an alternative way of giving your car throttle that is more electronic and less mechanised. It results in weaker throttle response. Look up drive by wire on google or something for more detailed info
