02 a4 1.8t chipped. need a little advice!!
Ok, so i have had my stock a4 for 8 months now and i am finally ready to take the plunge into chipping it. I am thinking of the giac chip because there are a few dealers close by. anyways, some guys are saying i need to add a bunch of stuff on top of the chip. I know i need a new DV but do i really need anything else besides that? should i be worried about other parts breaking down? i am not a racer, but would like a little more passing power.I'm on a budget and thinking this is the best way torwards a few more hp. any advice from you audi pros would be great! Thanks
ORIGINAL: stevem8
why a bosch dv? would a stock not hold up or limit psi?
ORIGINAL: stevem8
ohhh.. so it just wont last as long or ill feel the power limit? sorry for my noob Q's
If you left the stock dv in there and it broke your boost would be limited. There is a rubber diaphragm inside that will tear and will create an internal boost leak. The 710N comes with a better quality diaphragm and a beefier spring. Thats the only difference between the two. They are identical on the outside.
You dont have to worry about what it will feel like because you are going to replace the DV BEFORE you get chipped. Or, you should do it that way. The stock DV wont last long at all with a chip. Like, maybe a day or 2. So its not even worth finding out what the affects of the stock dv are with a chip. Get a 710N for $35 from http://www.purems.com/products/product.php/II=1752
thanks man, great info. ill get the dv 1st!!!
