03 A4 PO300 code (Intermittent)
Old Jan 4, 2011 | 10:27 PM
RDP595's Avatar
Default 03 A4 PO300 code (Intermittent)
Started up my Daughter's car today (It has sat for about a week or so: home from school: has ran fine up until now) was misfiring badly and came up with code PO300. Ran it for about 10 miles or so and it cleared up. My daughter drove it tonight and the same thing occured.
Had the coil packs replaced per the recall about 6 months ago.....looking for ideas.
Thanks,
Rick
Old Jan 4, 2011 | 10:42 PM
evelluser's Avatar
What kind of car is it? Mileage? Current on maintenance? We need more info then just the code.
Also, I have a 2000 S4, and got that code a few weeks ago. Ended up being a cracked vacuum line, which made my car run as if it was misfiring. Also, it could possibly be the mass airflow sensor. Try running the car with the MAF unplugged and see if it clears up. If so, then you may just need to clean it. After you clean it, plug it back up, and the car still runs bad, its most likely a vacuum leak.
Old Jan 5, 2011 | 11:03 AM
RDP595's Avatar
The car is an 2003 A4 quatto. Has about 91K on it...everthing up to date. Cleaned the MAP sensor this morning....see what happens.
rkelsey10554
Mar 11, 2014 10:52 AM
motorwerks1
Dec 20, 2010 09:34 AM
drsmith
Sep 21, 2008 12:38 PM
tsells1
Apr 29, 2008 02:07 AM
mikejda
May 25, 2007 08:47 PM
