034 Drive-By-Cable Conversion
Old Jan 19, 2006 | 09:48 PM
badassb5's Avatar
Default 034 Drive-By-Cable Conversion
Has anyone the the DBW to DBC conversion from 034 Motorsports? Is it worth the money to do it? What are the benefits?
Old Jan 19, 2006 | 09:51 PM
TomRitt's Avatar
Default RE: 034 Drive-By-Cable Conversion
well u only do this if ur switching to standalone, and thne it facilitates tuning
Old Jan 20, 2006 | 01:42 AM
ZedEx's Avatar
I can't stand the Drive-By-Wire set-up on the B6s... Which company makes a conversion kit for our cars? Any links?
Old Jan 20, 2006 | 02:08 AM
Jeff's Avatar
Zombie Defense Force
hey tom do u have a dbc kit or do i need to get one, or what stuff should i get?
Old Jan 20, 2006 | 02:51 AM
_Adrian_'s Avatar
well....
i dont remeber right but depending how much you willing to spend you might be able to get your ecm re-flashed for a DBC setup instead of DBW.
The only thing that might be needed is to modify the plug at the throtlebody and install the rest of the hardware wich would be the Pedal assembly, throtle cable, trotle cable bracket and also a new DBC throtlebody will be required to take place of the OE one)
Old Jan 20, 2006 | 05:09 AM
TomRitt's Avatar
yea i forgot about that jeff, i have a throttle body that might work, but a vr6 obd1 thorttle body would be a better choice. You will also need the cable, housing, and pedal cluster.
Also the dbc cars didnt have a flashable ecu so I'm not sure if that would work i guess maybe u could try to flash a dbc file onto a dbw ecu?
Old Jan 20, 2006 | 05:14 AM
tip5's Avatar
97 the golden year.
Old Jan 20, 2006 | 06:13 PM
badassb5's Avatar
Why would I only want to do this if I have standalone?
Old Jan 21, 2006 | 02:18 AM
trailboss's Avatar
Most people that have standalone have a BT and need a custom tune. Since chip tuning for BT setups are not a full true tune its is wise to go standalone to get the max out of the car with a good tune. How far are you going with your car? BT or just chip, k04 something along those lines. Most tuning for k04s and BT kits like apr and pes the tuning is good since your car is running everything for their tune. Once you start putting together a custom kit chip tuning isn't gonna be good.
shuggy81
Jun 19, 2013 12:38 PM
stebopp
Apr 27, 2006 07:32 PM
aaronamericahall
Dec 21, 2005 01:45 AM
YFZFourFifty
Jun 17, 2005 05:55 AM
