12mm spacer & extended studs HELP
Old Jun 26, 2007 | 07:49 AM
trini88's Avatar
Default 12mm spacer & extended studs HELP
what length extended stud would i need for a 12mm space and i assume it should be tappered as it's aftermarket wheels
HP EVO 18X8
audi a4 2006
TKS
Old Jun 26, 2007 | 11:38 AM
headshok2002's Avatar
Default RE: 12mm spacer & extended studs HELP
I'd make sure that the spacer is hubcentric...
And I'm not sure about the length. Measure your stock bolts and add 12 mm? :P
I can't remember the stock bolt size... I bet you can find it at ecstuning.com, though.
Old Jun 26, 2007 | 03:26 PM
trini88's Avatar
stock is 27mm + 12mm spacer = 39mm extended but i cannot get 39mm would 40mm be ok
tks
suprtran
Jul 24, 2010 11:17 AM
cwedholm1
Oct 19, 2009 09:50 PM
klum00
Mar 28, 2008 10:35 AM
klum00
Jan 14, 2008 11:52 AM
theguy1084
Aug 19, 2007 10:15 PM
