17s vs 18s
Old Jan 23, 2005 | 03:39 PM
audiboy1618's Avatar
Default 17s vs 18s
Ok, im looking into wheels but cant deside what to go with. I want all performance so they are def going to be lightweights. Everyone says that once you go over 17s you start to lose performace, i found 18s that weigh less then alot of 17s and about the same as stock. So im wondering for all you guys on 18s if you saw some performance drop? or a gain with lightweights and lowprofiles?
Old Jan 23, 2005 | 04:57 PM
Nickel_5000tq's Avatar
Default RE: 17s vs 18s
When you change wheels you better (must) keep the same diameter. But 16 on small cars use already very low profile tires. And if you go bigger the tire should be lower profile to keep diameter .
See tire calculator http://www.miata.net/garage/tirecalc.html
So bigger wheels might need same profile tires then the diam ll be bigger. Bigger diam means you loss torque, Hp, cause it ll be harder to do the same work.
Bigger with smaller profile means you keep the same performance (same diameter) but the ride ll be harder and maybe less fun.
Old Jan 23, 2005 | 09:58 PM
David_K's Avatar
you dont have to worry about power loss. you wont feel any difference in acceleration or anything.
Old Jan 24, 2005 | 06:48 AM
aaronamericahall's Avatar
anybody know what the stock wheel weight is and what are the lightest 18's to go with
Old Jan 25, 2005 | 12:56 AM
David_K's Avatar
go do reasearch
Old Jan 25, 2005 | 01:00 AM
brrman's Avatar
yeah - best to do your own research and figure out for yourself. No one here can tell you what appeals to you.
Took me months of looking.
Old Jan 25, 2005 | 02:02 AM
ORIGINAL: David_K
go do reasearch
been there done that.............I just figured since this is a Audi forum someone would give some of there own personal experience on this issue
Old Jan 25, 2005 | 02:06 AM
David_K's Avatar
just go to www.tirerack.com
Old Jan 25, 2005 | 02:20 AM
they have the old porsha wheels on sell for our car 19x8.5 for $169.00 a wheel but I called last week and he said that wheel weighs 30 pounds per wheel (very heavy)
Old Jan 26, 2005 | 01:00 AM
David_K's Avatar
do a 300ZX and look at the Moda R6 those are the wheels im putting on the car
