19" AT Italia 9 Razze Question
Old Mar 3, 2006 | 09:43 AM
KarlMarx's Avatar
Default 19" AT Italia 9 Razze Question
I was just wondering, if I got these 19" with low profile tires, would it fit my stock Non-sport suspension? I will eventually want to get the car lowered as well, with an Eibach Pro-plus kit, but was just wondering if it would look jacked without the suspension drop.
www.TireRack.com will mount and balance the tires for free, which means I can just change the wheels out without having to take it to the shop right? If I don't have to pay someone to swap the tires, I don't want too...
Thanks!
Old Mar 3, 2006 | 10:58 AM
sandman's Avatar
Default RE: 19" AT Italia 9 Razze Question
yea 19s will fit, you may have rubbing problems when you lower it but thats an easy fix. lower it first for sure.
Old Mar 3, 2006 | 11:00 AM
Jestnomen's Avatar
6th Gear
You better lower that thing first or you'll have the monster truck look!
Old Mar 3, 2006 | 12:50 PM
4ringstuned's Avatar
for sure. If your looking for that lowered look without the added price, you can buy some eibach sport springs for like $250. It depends on what width you get. I'm pretty sure you can fit up to 8.5s all around without rubbing. Once you hit 9 or 9.5, thats when your going to start rubbing. Also, if you have a quattro set up, you can't go for a staggered set up. You have to keep the same width all around.
Old Mar 4, 2006 | 03:10 AM
StepUpProductions's Avatar
iv heard that the staggered setup was fine and had no negative affect, i thought it was if you got like 19's in the back and 18's in the front is when you fvck your quattro... i could be wrong
Old Mar 4, 2006 | 06:48 AM
BadLuckAudi's Avatar
It all depends on the over all diameter, you can make them the same size its just challenging and you have to get the right tire set up, and it wil F%$K your quattro up if you dont make sure
ameglei
Nov 7, 2011 06:27 PM
devildog852
May 17, 2011 06:11 PM
bigmoneygrip
Feb 20, 2009 07:46 PM
FasTT
Feb 20, 2008 01:13 PM
KarlMarx
Apr 26, 2006 05:27 AM
