1996 Audi A4 Power Steering Fluid Leak Problem**HELP!!!**
Old Oct 24, 2007 | 04:50 PM
sineo's Avatar
Default RE: 1996 Audi A4 Power Steering Fluid Leak Problem**HELP!!!**
ORIGINAL: bren
do you think its worth me buying that Lucas stuff you mention? i've found it for sale, about £20 for a litre, let me know matey
It sure won't hurt and if it works, a great alternative to a $600 part replacement.
Old Oct 25, 2007 | 05:22 AM
bren's Avatar
awesome, thanks Sineo!
does anybody know how to bleed through the system on the PAS setup? a company just said to make sure there is no air in the system before i put this Lucas no more leaks stuff in.
thanks once again!
Old Oct 25, 2007 | 08:51 AM
bren's Avatar
***UPDATE***
spoke to my mate who runs a garage and asked him how to bleed the PAS system, he said to jack it up onto axle stands then start it up and hold the steering wheel in full lock on both sides. he said that there would be alot of noise (from pump)and bubbles (from reservoir) so i did that and after 5 mins the noise has virtually stopped. spoke to him and he said it was the air in the system which was causing the pump to make the sound.
so, it is now quiet again but i still haven't found the exact cause of the leak. i think i'm going to have to take the heatshields off from near the manifold and driveshaft cos i cant see anything with them in the way
will update again once i've done it
Old Oct 28, 2007 | 07:21 PM
bren's Avatar
**NEW UPDATE**
stripped alot of the engine bay out/inner arch etc to find the exact source of the leak.
i now know, it is coming from a broken seal inside the drivers side steering rack boot. the seal has gone causing the boot to fill up with fluid which has then split under pressure.
so it does need a complete new rack as the seals cannot be replaced or fixed seperately.
BUT, i dont mind, infact, it got me pumped up enough-that i want to fix it.
so, i've sorted out a complete PAS steering rack from a 1997 a4 1.8t, it'll arrive wednesday and i cant wait to fit it. its going to be difficult to do without taking the engine out but i'll manage.
i'll update the thread with pitures when it comes
cheers
copper07
Apr 7, 2012 10:03 PM
vtraudt
Feb 25, 2012 11:09 AM
2000A4_KS
Nov 15, 2010 12:44 PM
bwilcox100
Dec 6, 2008 04:09 PM
boy412
Jan 26, 2008 06:59 PM
