1997 a4 2.8 rear wheel bearing
I have '96 A4 Quattro. 2.8. Changed mine. Pressed. You will have a problem with the ABS Sensor tho. Be EXTREMELY Careful. You will NOT be able to pull out ABS sensor from the copper clamping sleeve so probably you will have to buy NEW ABS Sensor and clamping sleeve. I bought mine on amazon around $20, but I had to change the rubber garment and use the OLD one. DO NOT rip the old rubber garment. You will also need that copper clamping sleeve that it holds the ABS sensor. That I had to order from California because that was the only place where I found it. It was around $10 at that time if I remember good, but from what I can see now it's $11.38. Here is the direct link to see how it looks like.
http://www.rmeuropean.com/Part-Numbe..._1C748E02.aspx
It wasn't big deal. ABS Sensor was easy. I had bring mine in a shop to be pressed because I have no press
If I remember good wheel bearing didn't cost a lot ether. Good Luck to you.
Kyle_vdk
Jan 11, 2014 10:25 PM
