Help with a Fuel Pump Relay?
Old Jun 19, 2011 | 11:59 PM
makhack's Avatar
Default Help with a Fuel Pump Relay?
1996, Audi A4 Quattro 2.8 Manual, 248.000km (around 150.000 miles)
Problem:
Not Starting, Cranking, but NOT starting.
The car just staled on a stop sign. Few minutes before it stalled it start running crappy and lost power, like I downshifted from 3rd to 2nd and like it was running on 3-4 "cylinders" instead of 6 (little bit louder then usual).
Replaced:
Fuse checked. Fuel pump REPLACED.
I have a no knowledge if the fuel pump relay works. Relay number is 8A0951253B (208 on the top). Is there a way to check it if the relay is OK? I have the relay pulled out and ready to buy one, but what if it's NOT the relay. I have a Multimeter, so is there a way to
check if the relay is OK or is it possible that is the fuel filter? Fuel filter should be OK tho, because it was replaced about 4 months ago. (the old one corroded and start dripping fuel). If the relay is OK, is there any way I can check to see if fuel goes to the engine? Or could be some "other" problem with my car.
Any suggestions and help appreciated.
Thanks,
iastudilloi
Sep 27, 2018 04:41 AM
jsethwerner225
Nov 14, 2014 01:55 PM
elye1231
Jun 20, 2011 08:56 PM
driftking8732
Jan 25, 2009 11:47 AM
rnbguy
Jun 29, 2005 11:07 AM
