1997 a4 oil change DIY?
Old Jun 3, 2005 | 05:26 AM
fritz's Avatar
Default 1997 a4 oil change DIY?
i have the 1.8T and do not have the owners manual for it. Does anyone know which type of oil to use, from researching, i need synthetic but which type and weight?
also, is it easy enough to change out the oil myself and if so is there anything special that I need to know like how to take off the skid plate?
Thanks in advance
Old Jun 3, 2005 | 05:49 AM
BFlan2001's Avatar
Default RE: 1997 a4 oil change DIY?
mobil 1, 0w40
Old Jun 3, 2005 | 09:29 AM
david9999's Avatar
Nothing special, but if you have a tiptronic, make sure you drain the oil not the transmission fluid. Get Mann filters over the internet, of if no time, get one from the dealer.
See if you can pick up a haynes manual at pepboys for Audi/VW. it is only about 15 dollars
Old Jun 3, 2005 | 12:35 PM
CRAZYHAWK's Avatar
Bentframe, I use the same as you. It meets ACEA A3.
Old Jun 3, 2005 | 01:09 PM
Jestnomen's Avatar
6th Gear
Pick up a set of Rhino Ramps too, they are very helpful for oil changes. Much easier than jacking the car up.
Old Jun 3, 2005 | 02:33 PM
fritz's Avatar
so dont go for the fram filters???
Old Jun 3, 2005 | 02:38 PM
black991.8tq's Avatar
no dont use fram,dont use anything but MANN brand filter u can get em from a dealer or internet or a european parts store. the skide plate is easy no special tools
Old Jun 3, 2005 | 03:04 PM
brrman's Avatar
I have used K&N on occasion too. Mann or Bosch are stock filters.
Old Jun 3, 2005 | 03:09 PM
skidplatexa4's Avatar
Why not use Fram? I get parts through my friend at a Dodge dealer so I pay 5% over cost which is good,but still what are your feelings about Fram I still use them on my Chevy.
Old Jun 3, 2005 | 03:11 PM
exactly chevy not audi check the inside of a mann filter it is different
