1997 a4 oil change DIY?
Old Jun 3, 2005 | 03:13 PM
skidplatexa4's Avatar
Default RE: 1997 a4 oil change DIY?
Next time I will never looked or paid any attention to it. Thanks
Old Jun 3, 2005 | 03:29 PM
fritz's Avatar
im able to pick up bosch at autozone, will that work?
Old Jun 3, 2005 | 03:50 PM
BFlan2001's Avatar
ORIGINAL: fritz
yes
Old Jun 3, 2005 | 05:12 PM
Jestnomen's Avatar
6th Gear
You can use Mayle filters as well.
Old Jun 3, 2005 | 06:06 PM
fritz's Avatar
last question and thanks for all the replies. how many quarts should i buy?
Old Jun 3, 2005 | 07:36 PM
david9999's Avatar
Buy 5 and you will use 4
And don't over tighten the drain plug. Use a torque wrench.
When you buy new filters from ECS tuning, also get new copper washers for the drain plug.
Old Jun 3, 2005 | 08:02 PM
flyinb501's Avatar
Will all your oil drain if you use those ramps seeing as the car will be inclined? If you use a jack you can let the car down while the oil is draining. Don't get me wrong I would rather use the ramps.
[quote]ORIGINAL: Jestnomen
Pick up a set of Rhino Ramps too, they are very helpful for oil changes. Much easier than jacking the car up.
Old Jun 3, 2005 | 08:17 PM
  #18
audiboy1618's Avatar
I use mobil 1 15w 50, fully syn
Old Dec 25, 2008 | 01:13 PM
  #19
kr1snarowsk1's Avatar
the reason u can't use fram is bc the different filter is found to cause the turbo to sludge. Now u don't want that to happen now do ya?
MartinCieslak1
Sep 24, 2010 11:21 PM
hellperados
Sep 7, 2009 10:39 PM
sollyd25
Jun 27, 2008 01:52 AM
fritz
Jun 9, 2005 04:36 PM
macky2114
Apr 1, 2005 02:09 AM
