1999 A4 1.8T Turn Signal
Old Dec 3, 2006 | 11:54 PM
SpeedTL's Avatar
Default 1999 A4 1.8T Turn Signal
Hi All!
First post!
My wife has a 1999 A4 and the turn signals are not working properly. The turn signals work intermittently. Sometimes they flash, sometimes they just stay lit. The hazards work fine. I did a search and it seems that other Audi owners replaced the hazard switch. That solution seems to work for 2001 and up models. Does anyone know if it is the same for the 99's? I did see some relays behind the fuses, does anyone know which relay is which?
Thanks for any info!
Old Dec 4, 2006 | 07:32 AM
BadLuckAudi's Avatar
Default RE: 1999 A4 1.8T Turn Signal
you should try replacing the little blinker module thing
Old Dec 6, 2006 | 06:42 AM
SpeedTL's Avatar
So you're saying that the hazards and the turn signals use the same relay like the newer models?
Old Dec 6, 2006 | 09:10 AM
techbod's Avatar
they do but it could be a bad ground or the indicator stalk is shorting out or need the contacts cleaning
Old Dec 7, 2006 | 07:01 AM
SpeedTL's Avatar
Thanks for the input Dave. Any suggestions on what to do to diagnose the problem?
peterelwood01
Jan 6, 2010 12:05 AM
pa4ul
Jan 21, 2008 03:20 PM
mdudu
Jun 12, 2007 03:20 PM
ALL*AUDI
Jun 4, 2005 11:56 AM
paliracer
Feb 21, 2005 03:15 PM
