1999 A4 2.5tdi Stalling
Old Nov 1, 2011 | 02:55 PM
john.storey's Avatar
Default 1999 A4 2.5tdi Stalling
Hi All, I have a A4 avant 2.5tdi 1999. It runs fine up to 3000 RPM then cuts out, the car restarts ok after this. Doesn't matter whether the car is stationary or moving. Any help would be greatly appreciated.
Old Dec 7, 2011 | 04:40 AM
AudiInfantry's Avatar
Has it done this before? Are there engine codes? I had a similar problem with an older cavalier I once had, in the higher RPMS it would start cutting out, and stall going up hills, or when speeding up rapidly would sometimes cut out.(automatic) have you checked to see if all your plugs/coil packs are in place?(problem with cavalier, changing them fixed the problem mostly) My last 99A4 2.8 had an issue with Idling, very rough, and not smooth and consistent. it would hop from 1.5 to just under 1k and almost stall if i didn't give her some gas. never did get it fixed though, getting hit took care of that unfortunately. :/
Other this problem, how do you like the car? I'm planning on getting the same car this weekend possibly, here in Germany.
I bought the car, and I haven't noticed this problem, 246k km(156k miles roughly)
Last edited by AudiInfantry; Dec 12, 2011 at 07:57 AM. Reason: Update on buying car
AudiInfantry
Dec 13, 2011 05:19 PM
jonty3962
Dec 8, 2011 05:34 AM
Rufio-plb
Dec 2, 2008 10:50 AM
Plopper
Feb 8, 2008 07:25 PM
nasti
Oct 9, 2005 07:59 AM
