1999 A4 2.8 Will not start
Old Dec 17, 2006 | 02:36 PM
techbod's Avatar
Default RE: 1999 A4 2.8 Will not start
I suppose you have tried changing the fuel pump relay?? only other thing I can think of is the immobiliser or fuel pump trip switch ( if it has one ) this would cause a low voltage
Old Dec 17, 2006 | 02:40 PM
blackraven's Avatar
where is the immobiliser or the fuel pump trip switch located?
Old Dec 17, 2006 | 02:53 PM
techbod's Avatar
fuel pump trip ( if fitted ) UK models don't have them on the earlier cars, immobiliser is a chip in the key
[IMG]local://upfiles/12092/9C30CB4D09024B7ABB28CB6136793DAF.jpg[/IMG]
Old Dec 18, 2006 | 03:59 PM
MattyAudi's Avatar
Did you just recently have the timing belt replaced? Did the timing belt go? Perhaps you busted a cylinder head. Just 3 weeks ago I was driving around my 1999 2.8 and I stopped for 10 minutes and when I got back into my car it wouldn't start. I hadn't had any problems driving around prior. Everything seemed fine, it just would not fire. I had to have the car towed to Audi, the timing belt went and had 2 busted heads. They said it was going to be $8K to fix, so I just bought a new car.
Old Dec 18, 2006 | 07:13 PM
Pson's Avatar
Hmm...could be didn't you ask about a rpm shutter problem before?? that could be it. But I would just say open the gas tank and crank the V6 a few times and about the 4 time it should start...then walk out and put the cap back on and run like you stole it
Old Dec 2, 2007 | 09:35 PM
wings7351's Avatar
Blackraven, I know this thread is about a year old, but I am desperately looking for a solution to the same issue you described. The only difference is that at both the fuse and fuel pump I am getting 4.17V when the key is at ON, when I crank the engine, it goes to more than 10V, which I suppose is the battery voltage.
I am just wondering if you have solved the problem and if yes, could you share your findings with me.
Thanks.
lianne_m_jones
Oct 13, 2013 05:00 PM
sakana
Aug 31, 2011 04:12 AM
fpoljanec
Jan 18, 2009 06:21 PM
nickerstick
Oct 20, 2007 10:58 AM
beauregard
Jan 26, 2007 01:12 AM
