1st to 2nd gear squeal noise
whenever I'm getting on it very hard from the 1st to 2nd gear I hear this squeal noise like the belt is going bad but the belt is good, it only do this when I'm getting on it or whenever I luanch it. anybody have had this or know what this is
no it seems to be normal, I'm thinking that maybe when I get on it I put alot of stress on the belt or the fan which cause it to squeek when I get on it, it only makes a quick chirp squeek noise when I shift into the 2nd gear going very fast and high rpms
I don't get this on my 98.5...I wonder if its something with your clutch engaging. A stage 2 clamps harder, this might cause a noise at high RPM's. Do you notice it right as it goes into gear?
-T
-T
well today I drove my ride by a friend of mine and he say it sounds more like I'm scratching in the gear, THis is driving me crazy it sounds like I can't drive a stick when it does this its embarassing.
Grinding going into the gear,BFlan2001, you cant really do anything except a new tranny or synchro, i did it one day racing and it started to grind, then it just got worse and then i race again and that was the end of it.
