1st Gear Boost
Old Apr 27, 2006 | 03:07 PM
kaklexicon's Avatar
Default 1st Gear Boost
Is it normal for first gear to boost lower than the rest of the gears? check my mods. In second and up i usually hit around 15 psi, but first never goes above 10 psi.
Old Apr 27, 2006 | 05:18 PM
dafrazi's Avatar
Default RE: 1st Gear Boost
Yes that is normal.
Old Apr 27, 2006 | 05:33 PM
techbod's Avatar
1st gear is designed to get you going forget the turbo in this gear, 2nd/3/4/5/6 are pickup gears due to their ratios and turbo has best effect in higher gears unless its modded
Old Apr 27, 2006 | 05:46 PM
kaklexicon's Avatar
That's what I wanted to hear! I'm glad it normal and nothings wrong.. Thanks for the info.
Old Apr 27, 2006 | 08:21 PM
BadLuckAudi's Avatar
yea your poor lil k03 cant really keep up so the boost is lower in first
Old Apr 27, 2006 | 08:47 PM
kaklexicon's Avatar
Interesting. So a K04 would hold higher boost in 1st gear then?
Old Apr 27, 2006 | 09:42 PM
dafrazi's Avatar
No. The ECU doesn't ask for as much boost in 1st.
Old Apr 27, 2006 | 09:50 PM
no its not that it doesnt want it, its that the turbo cant produce it under those conditions and yes a k04 would do much better there and everywhere else its a much more efficient turbo
Old May 1, 2006 | 11:44 AM
dafrazi's Avatar
I stand corrected. I did a little digging and the ECU does request almost the same boost in 1st as it does for 2nd and 3rd. It's maybe a 1/4 psi less if that.
Old May 1, 2006 | 11:49 AM
Slowb5's Avatar
uh boy......
