1st gear going any speed?
Old Jun 29, 2007 | 01:40 AM
flake's Avatar
Default 1st gear going any speed?
Are you supposed to be able to shift into 1st gear going any speed or is there some type of limiter that makes it so you can only shift into 1st when you are going slow or stopped?
2002 Audi A4 3.0L QM
Old Jun 29, 2007 | 02:05 AM
auditech79's Avatar
Default RE: 1st gear going any speed?
I think they make the synchronizer gear a little smaller so its harder to engage 1st to prevent you from blowing up your engine. A limiter? i don't see how they can put a limiter in an all mechanical transmission that you control.
Old Jun 29, 2007 | 02:37 AM
a4 1.8t's Avatar
ORIGINAL: auditech79
+1 you should have to push it pretty hard to get it into first.. what are you doing putting it into first anyway at any speed? There is the rev limiter but that wont really do anything if your shifting into first going way to fast for first gear, you will overrev and bend all ur valves
Old Jun 29, 2007 | 02:42 AM
flake's Avatar
got ya.. btw i'm not doing this I was just curious though.
Thanks
Old Jun 29, 2007 | 09:19 AM
EJ30157's Avatar
The same should apply to reverse gear I think.
Old Jun 29, 2007 | 11:14 AM
onepoint8tee's Avatar
Just get r up to 90 and slam it into first... See what happens and let us know.
Old Jun 29, 2007 | 11:53 AM
AteUrV8's Avatar
ORIGINAL: onepoint8tee
ya im curious...
Old Jun 29, 2007 | 11:54 AM
fenderstrat1184's Avatar
LOL
harsh
Old Jun 29, 2007 | 12:17 PM
EJ30157's Avatar
If you can't put in first after you hit 90mph, try throwing it in reverse.
Old Jun 29, 2007 | 12:21 PM
A4Rollin's Avatar
if all fails just rev your motor up to redline for about 5 minutes, then you should be good!
[/align]
