1st gear jerky
Old Jun 16, 2005 | 06:05 AM
conspirisi's Avatar
Default 1st gear jerky
Hello,
i got a audi 1.9 Tdi 1996 and it seems to be very jerky accelerating in 1st gear. Accelerating in all the other gears are ok.
it seems to get worse after I have driven alot.
so whats up?
Old Jun 16, 2005 | 07:44 AM
rs's Avatar
rs
Default RE: 1st gear jerky
what kinda tranny?
Old Jun 16, 2005 | 07:58 AM
conspirisi's Avatar
manual.
if that what you mean. I got a degree in engineering but don't know nothin about cars
Old Jun 16, 2005 | 09:52 AM
dafrazi's Avatar
It's normal for first gear to be jerky.
If you're new to this car, the jerkiness will get better as you get used to driving it. The reason it's jerky is the gear ratio.
Old Jun 16, 2005 | 11:52 AM
conspirisi's Avatar
thanks dafrazi.
but if it was the gear ratio, it wouldn't get worse after I drive it a couple of dozen miles. right?
when you start the car cold accelerating in first is fine. Its not so much accelerating as manovering slowly in first gear that is the prob.
Old Jun 16, 2005 | 12:04 PM
Danase's Avatar
This is just a dumb thought...but is your A/C on when this is happening?
Old Jun 16, 2005 | 12:13 PM
conspirisi's Avatar
yes. i never switch the AC off (incidently does that use more fuel?)
Old Jun 16, 2005 | 12:50 PM
Danase's Avatar
Yes, the A/C robs the motor of power and gives you worse gas mileage. It could be jerky just because the A/C pump is on. Try it with the a/c off and see if that helps.
Old Jun 16, 2005 | 02:20 PM
Mr_You's Avatar
Are you new to manuals? Maybe you just need some practice?
Old Jun 16, 2005 | 02:48 PM
conspirisi's Avatar
never touched an automatic. I'm from the old skool europe
