2.8 coolant leak...
Old Jul 31, 2006 | 05:32 PM
lemke's Avatar
Default 2.8 coolant leak...
After changing the timing belt, water pump, thermostat, coolant reservoir, the little bastard still wants to leak coolant. Is there a "typical" place that the 2.8's are prone to leak from. Its apparently dripping down from the front of the oil pan... I previously suspected the waterpump. Any ideas from those familiar with the V6 variety?
Thanks in advance.
Old Jul 31, 2006 | 05:39 PM
techbod's Avatar
Default RE: 2.8 coolant leak...
leaky water pump seal/hose, double check it
Old Jul 31, 2006 | 05:45 PM
techbod's Avatar
there was an issue of coolant leak below the plenum/intake but was more to the rear of the engine
Old Jul 31, 2006 | 05:55 PM
lemke's Avatar
There appears to be a coolant "tube" that is visible from the front of of the motor(with the water pump removed). Are there seals (o-ring) that are prone to leak on this part? And I presume this tube runs below the intake manifold to the rear of the motor... yes? I really don't feel like tearing into this car again in this wonderful Texas heat. I hope it is as simple as a hose needing replacement. Any other thoughts?
Thanks-
Old Jul 31, 2006 | 06:09 PM
techbod's Avatar
one problem when working on cars is when removing hoses that are old (they split) and the only time you notice is when its back together, a swine really its happened to me on many occasions
Old Jul 31, 2006 | 11:19 PM
klum00's Avatar
yeah im in the process of doing all that to mine. so im keeping my fingers crossed...since im not replaceing the tubing.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
supacor24
Jun 3, 2011 07:56 AM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
