2.8 starting problems?
Old Nov 10, 2007 | 04:16 PM
stahly22's Avatar
Default 2.8 starting problems?
-car will start just fine for a month or so
-then randomly it will just turn over and not start, and it seems like its flooding itself because ill smell gas fumes?
-it will putter and start all crappy after i let it sit for a bit, finally after running it revs up a bit to around 2k
-after its done it goes back to normal until it happens again
there is a check engine light on, but when we checked it, its an emissions code
but last night it happened and this morning it happened again
so i thought id see if anyone has any ideas on what’s wrong before i go talk to the audi stealership about it
Old Nov 10, 2007 | 04:22 PM
stahly22's Avatar
Default RE: 2.8 starting problems?
im wondering is it some kind of sensor that is going out? because basically everything is tied together through sensors in these cars lol
Old Nov 10, 2007 | 04:51 PM
LowA4's Avatar
What happened in mine was after driving it and it was warm and I shut it off, it would just turn over and not start. I had to hold the gas pedal all the way to the floor while turning it over. It was the coolant temp sensor which was $36 from the dealer and took me 15 minutes to install.
Old Nov 10, 2007 | 05:04 PM
auditech79's Avatar
Yeah the CTS is gonna be the most likely cause, and it tends not to throw a fault code.
Old Nov 10, 2007 | 05:16 PM
crayzdavy's Avatar
Probably the CTS but it could be the crank postion sensor which was the cause of my NON-start problem.
Old Nov 10, 2007 | 07:10 PM
MissingLink's Avatar
Dude here is the problem belive it or not the water temp sensor replace and everything will be fine it took me like 10 minutes to do buy the sensor and gasket and clip just in case
Old Nov 10, 2007 | 11:10 PM
stahly22's Avatar
thanks for the quick replies guys, yeah it happend again and i let it cool down for awhile... then it still wouldnt start, so when i about gave up i was going to push it over to a parking spot by the gas station and it started thank god...
but first thing ill try is the cts, install that and if the problem persists ill go in and think about other options suchs as the crank pos sensor...
thanks alot!
Old Nov 11, 2007 | 12:08 AM
hiwords's Avatar
if it's the crank position sensor, u should be getting a CEL. get ur fault codes read too
Old Nov 11, 2007 | 11:38 AM
wood_e's Avatar
^ not necessarily - post what fault codes you get...
Old Nov 11, 2007 | 11:39 AM
techbod's Avatar
^^ fault codes and save money
