2.8 turbo, it can be done...
Old Aug 16, 2007 | 01:42 AM
oneg's Avatar
Default 2.8 turbo, it can be done...
...im hoping, me and my friend, whos a machinist are doing are homework and have come to the conclusion to make a custom turbo manifold for my 12v 2.8. we have acces to all the materials and tools we'll need, and then ill be purchesing the turbo. As far as im concernd it can be done? if anyone has any further imput, please speak out.
Yet i am doing this more for the sake of doing...not just to make my car faster, so please dont argue about if its worth it or not, or tell me i shoulda just got a 1.8t.
when i do get it done, however long it may be ill be sure to post pics.
Old Aug 16, 2007 | 04:34 AM
blakhaüs's Avatar
Default RE: 2.8 turbo, it can be done...
good luck bro...im interested in seeing the outcome.
Old Aug 16, 2007 | 04:56 AM
dombombBMX's Avatar
sweet deal... yeah let us know how it goes. i got the 2.8 30v. im not gonna turbo it but im interested in you doing it.
i know people say its not worth it. but i know its going to make a very noticable difference. it has to. good luck
make sure to post maybe some pics or some video or something, take it easy.
Old Aug 16, 2007 | 05:35 AM
CLX's Avatar
CLX
Zombie Defense Force
Umm, you know that you have two manifolds, so it's going to be tricky trying to fit one turbo to that. Plus, the 2,7 engine is essentially the same engine as the 2,8 but with thicker cylinder walls to handle the added HP and pressures associated with boost. And don't forget the custom ECU programming. It's going to be much much more than just making a manifold and buying a turbo and hoping it all goes together.
Old Aug 16, 2007 | 07:24 AM
hiwords's Avatar
there's an audi on cardomain that has a remote mount turbo. i found it when i was looking for turbos for ma 2.8 lol good luck man i rly hope it works, but just be careful not to boost too much.
Old Aug 16, 2007 | 10:08 AM
Lazer Viking's Avatar
10 bucks says this one will never get finished either.. people have started this project countless times in the past
the only one to be successful, was on a passat
Old Aug 16, 2007 | 10:34 AM
klum00's Avatar
The turbo and manifold are not the issue for this project. Its the timing/ecu. The 2.8s come with a hitachi ECU which cannot be upgraded, EVER. The only way to make this work (correctly) is with stand alone engine management i.e. megasquirt. You will need to spend countless hours figuring out the correct timing and could risk serious damage to your car while doing so. If this is your DD and you cant afford to get a new car if something happens, I would highly recommend against trying.
Research this topic more thoroughly on the 12v section of AudiWorld, Audizine, here and Fourtitude.com
Old Aug 16, 2007 | 11:21 AM
cincyTT's Avatar
I'm make believe
So where will this TURBO (singular) be located?
And what turbo you going with?
Old Aug 16, 2007 | 12:22 PM
2k S4's Avatar
Get a stock 2.7t one, & put it on.
If you want to do it cheap, get an adjustable FPR & a wideband. Between that & Lemi you should be able to tune it around 75%.
Old Aug 16, 2007 | 12:25 PM
oneg's Avatar
yeah, didnt mean to make it sound like thats all i thought it would need.
