#2 cylinder Misfiring
Ok so I started my car, while still warm, and it started stuttering-at idle and while accelerating was worse. Chk Engine light came on. Took it to autozone-free daig- says it #2 cylinder misfiring. What is weird, is if I start it cold, it is fine, but if I cut it off and then try to restart, it is crappy again. Could this be the coil pack? I checked the wires and plugs, everyting looks good. Any ideas?
Take the coil pack off cyclinder 2 and put it on 1 or 3. If the misfire changes, replace the coil pack. Also check the spark plug. I had the same problem a bout three months ago and it turned out to be a cracked spark plug. Course the dealer tried to sell me a new coil pack. After I figured out it was only the plug I kept the new coil and made them give me my money back.
I bought a new coil, replaced #2, it did not work....i swaped each cylinder out, one at a time, no positive results. Any help at all? I also changed the plugs..no avail....i am getting desperate here.
Possibly, depending on the engine.
run a search on misfire cyl 2 here or on audiworld. As I recall, there were a batch with bad connections for cyl 2 causing misfires. Someone on audiworld took it apart and found the problem.
