2 new tires?
Old Mar 21, 2007 | 06:13 PM
ou2mame's Avatar
Default 2 new tires?
One of my tires' sidewalls blew out. is it alright to get only 2 new tires, with the awd?
Old Mar 21, 2007 | 06:16 PM
Karl's Avatar
Default RE: 2 new tires?
no you should get four new tires..
Old Mar 21, 2007 | 06:23 PM
MissionCtrl's Avatar
if you can find 2 used tires that are the same tread depth/tread pattern as the ones you are leaving onyou could get by until you need all 4 replaced.
Old Mar 21, 2007 | 06:58 PM
wood_e's Avatar
I just bought 2 used tires to replace the dead continentals on my front - $100 I bought the same pattern and the same sort of wear as the rears so it should be fine.
Old Mar 21, 2007 | 11:22 PM
Amze's Avatar
Man, its fine to just buy 2 new ones... Don't trip about it, just make sure you get the same exact tire...
I just replaced only 1 of my tires, works great... my other ones are only 6 months old and look like there brand new.. AWD makes tire wear... non-exsistant
Old Mar 21, 2007 | 11:27 PM
Belligerenceā„¢'s Avatar
the issue with replacing only one tire on an all wheel drive vehicle is that the new tire has a larger diameter than the old ones. this creates havoc with the differentials, and can cause unnecessary wear. as missionctrl said, if you can find 2 tires that are of similar tread depth and pattern as yours, then you would probably be ok until you have to replace all of them.
Old Mar 22, 2007 | 06:28 AM
ou2mame's Avatar
yeah, the tires that are on there are about 50% worn, so i was wondering if it would be alright to just replace two. but, i dunno. i'm used to 4x4 trucks, and i know better than to replace just 2 at that point, but i'm not sure about awd. my dad is going to pay for it (thank god, i'm a poor college student), but i don't want him to have to pay for 4 if its not required. if i was go get 2 tires, they're going to be new most likely. i'll get 4 if i have to, but i don't want to if i don't have to.
bigatstyle
Nov 9, 2012 08:29 AM
dlyskawa
Dec 17, 2007 12:32 PM
pindonesia
Nov 16, 2005 11:43 PM
jmerrell
Aug 25, 2005 04:01 AM
miamitrails
Aug 17, 2005 03:08 PM
