2 Questions
Old Feb 16, 2006 | 01:54 PM
kaklexicon's Avatar
Default 2 Questions
1. How many miles is the original alternator good for?
2. 2nd gear is hard to shift into, does this mean i need a new clutch? None of the other gears are hard, just 2nd.
Old Feb 16, 2006 | 01:58 PM
18T's Avatar
18T
Default RE: 2 Questions
1. i dotn know
2. some gears are like that. for me reverse is hard.
Old Feb 16, 2006 | 02:01 PM
kaklexicon's Avatar
.. is there anything i can do to fix it apart from a new clutch?
Old Feb 16, 2006 | 02:05 PM
18T's Avatar
18T
its not your clutch thats the problem
Old Feb 16, 2006 | 02:16 PM
clconversion's Avatar
does the hard shifting just happen when it is cold ? this is normal
as for the alternator I have worked for Audi for almost 7 years and probley only seen a handful of them replaced not a common problem at all
Old Feb 16, 2006 | 02:27 PM
kaklexicon's Avatar
Ok, thanks, good to know about the alternator.
As for 2nd Gear, it is worse when it's cold, but even when it's warmed up it's still harder than the other gears.
Old Feb 16, 2006 | 02:34 PM
no gears are grinding are they ?
Old Feb 16, 2006 | 02:47 PM
kaklexicon's Avatar
Not as far as i can tell, they all sound fine, what should I be listening for?
Old Feb 16, 2006 | 02:52 PM
techbod's Avatar
bleed the clutch slave cylinder
Old Feb 16, 2006 | 02:57 PM
Matori1.8t's Avatar
1. dont think any time soon..
2. i have the same issue.. sometimes its harder sometimes it not.. when its cold its hard to shift.. i have a buddy in a b5 who also has that same problem. dont kno what it could be..
