2000 A4 1.8T has codes for running lean and misfires
Old Sep 5, 2007 | 10:18 AM
BuckWyld's Avatar
Default 2000 A4 1.8T has codes for running lean and misfires
I got this car recently and the check engine light came on, the codes reported that the car was running lean, and some misfires. I have replaced O2 sensors (2), ignition coils (4), spark plugs (4) and it doesnt seem to be any better, and it may actually be worse. What is going on here? Please help I am starting to not like this car. Also I have ~65k on the odometer should I worry about the timing belt before the 90k they suggest?
Old Sep 5, 2007 | 10:21 AM
CRAZYHAWK's Avatar
Default RE: 2000 A4 1.8T has codes for running lean and misfires
Check for vacuum leaks.
Old Sep 5, 2007 | 10:22 AM
ironman's Avatar
or try and replace your fuel filter, that can get clogged and stop the flow of gas.
Old Sep 5, 2007 | 10:28 AM
BuckWyld's Avatar
no vacuum leaks. would a clogged fuel filter cause misfires? my mechanic seemed to think that the old plugs showed signs that the engine was running rich because it was compensating for the codes saying that it was lean when it was not, that is why we started with the O2 sensors after checking for vacuum leaks.
Old Sep 5, 2007 | 01:01 PM
captcaos2002's Avatar
ignition control unit
Old Sep 5, 2007 | 01:09 PM
BuckWyld's Avatar
Is the ICU the same as an ICM? I found a link to a way to test the icm, but it seems to be for '99 and earlier cars, will it still work for mine? what are the wires that lead in to the coil pack called?
this one --> http://forums.audiworld.com/a4/msgs/1594531.phtml
Old Sep 5, 2007 | 01:59 PM
BuckWyld's Avatar
also how can I tell which sort of A4 I have? I know it is a 2000 1.8T quattro, is it the B5?
Old Sep 6, 2007 | 09:09 AM
CRAZYHAWK's Avatar
You don't have an ignition control module.
Old Sep 6, 2007 | 09:58 AM
BuckWyld's Avatar
So what else could the problem be? Is there a way to test the ecu? the Air flow mass sensor is different from the O2 sensor right?
Old Sep 6, 2007 | 10:24 PM
david9999's Avatar
Can you post the actual codes so that we can look up the causes.
