2001 with Giac K04, Boost Problem
Old Jun 1, 2006 | 06:57 AM
FantasiA4's Avatar
Default 2001 with Giac K04, Boost Problem
I have a 2001 with ECU code CH. I got the k04 and the Giac chip.
Here's my problem. The car holds about 18-20 psi. I drive it around for about a week then I notice that the boost will
only go up to about 13-15 psi. I was frustrated the other day and I resetting the ECU by disconnecting the battery. Got in
the car and boost goes back up to 20 psi. After a few days boost is back down 13-15 psi. Reset the ECU and boost is back up again.
Any ideals of what's wrong? I have heard about 2001 with KO4 GIAC have the throttle closing when boosting over 21psi.
Old Jun 1, 2006 | 11:21 AM
north5995's Avatar
Default RE: 2001 with Giac K04, Boost Problem
Have you replaced/upgraded your N75 valve?
You may have to use a boost controller in combination with your N75 valve as us DBW guys have that throttle closing problem. You may be hitting the 21psi and just don't know it for a split second.
Old Jun 1, 2006 | 07:43 PM
FantasiA4's Avatar
I was thinking about the MBC. I'll drive it around for a couple of days with out hitting high boost and see what happens.
Old Jun 1, 2006 | 07:44 PM
18T's Avatar
18T
that throttle closing problem..yukk.. its common with us 01 guys.
Old Jun 1, 2006 | 09:14 PM
JettaRedII's Avatar
ORIGINAL: north5995
Actually, it may be more than just an overboost problem.
GIAC has come out with the "hammer" file which requires larger injectors and a TT225 MAF (at a minimum) to resolve the throttle closing problem. The thinking is that the ECU is shutting down the throttle body based on a number of conditions that it considers "unsafe". Namely, the problem occurs at high boost, high load and high rpm.
Those conditions require the fuel injectors (even at 5 bar) to excede the normal operating duty cycles of the stock injectors for too long. (How long is too long? Dunno. Several milliseconds?) In order to prevent the engine from running distructively lean due to sudden injector failure, the ECU shuts the throttle body down.
So...using all sorts of crazy work arounds may diminsh the symptoms, but they don't cure the problem.
I haven't heard of any other major chip maker offering a software only solution for the K04. Does APR? (I know Revo doesn't.)
Old Jun 2, 2006 | 10:03 AM
dafrazi's Avatar
Where did you read about this hammer file?
I've read about where the Torque Factory's is doing some tuning with GIAC for the '00 and '01 but, last I heard they were just calling it FX, like the B6 K04 file. The "FX" file is also supposed to fix these problems.
Old Jun 2, 2006 | 10:13 AM
JettaRedII's Avatar
ORIGINAL: dafrazi
Maybe they're the same and "hammer" is the code name. It is the file that Jeff and Garrett jointly developed.
Old Jun 2, 2006 | 01:13 PM
dafrazi's Avatar
Yeah probably the same thing. I assume you mean Jeff Moss, the Torque Factory guru.
Old Jun 2, 2006 | 03:43 PM
north5995's Avatar
ORIGINAL: JettaRedII
ORIGINAL: north5995
Humm... Is this the same problem I am going to have being a '00? I will be running the J-31 file. Do you have the 5.0 FPR? You need that when you go K04. I wouldn't have though the larger MAF was required.
Old Jun 2, 2006 | 07:36 PM
FantasiA4's Avatar
Anyone have the phone number to Giac? I try looking on there site but its not there.
