2002 audi a4 quatro 1.8t stuck in park
Old May 15, 2013 | 09:47 AM
djalby's Avatar
Default 2002 audi a4 quatro 1.8t stuck in park
any help out there?
brake lights work.
the little foot light on the shifter does not light up anymore.
can't take car out of park
checked fuses .
Old May 15, 2013 | 10:10 AM
CryptoStorm's Avatar
There is a switch attached to the break pedal that has 2 sets of contacts. 1 for the computer and 1 for thebreak lights. Its probably the culprit.
You might be able to clean the contacts. Or it might be beyond repair; if it is they're about $60 if I remember right..
To remove it from the car you need to twist it about 45 degrees (it should twist IN ONE DIRECTION fairly easily) and it will basically fall out.
To test it you will have to force the little plastic piece back the other way 45 degrees with a screwdriver in order for the contractors to make a connection. Be sure to twist it back before trying to reinstall.
Old May 17, 2013 | 10:32 AM
djalby's Avatar
Smile thanks for your responce
luckily car wasn't towed out of parking lot.
a friend of mine was able to unplug the SELENOID located inside the shifter.
every light is now on the dashboard but at least the car can be driven until I replace that solenoid.
thanks for your help
Old May 17, 2013 | 11:08 AM
if the solenoid disengaged when you unplugged it, then that means the solenoid was working properly.. I still maintain its the pedal switch.
check for voltage to that pigtail when the car is in park
dpoverby
Jan 10, 2022 10:42 PM
paulywalnuts446
Dec 22, 2018 03:01 AM
mctruth3
Nov 19, 2011 02:19 PM
gahndai
Jul 12, 2009 02:27 PM
Hoguenstein
Mar 6, 2009 12:56 AM
