2007 Audi A4 2.0 Randomly doesnt start
Old May 3, 2013 | 10:49 AM
rgwilliams44's Avatar
Exclamation 2007 Audi A4 2.0 Randomly doesnt start
Has anyone run into a problem where there 07 A$ doesnt start? Then say after a couple of hours will start again. What is the cause?
Old May 3, 2013 | 10:29 PM
Nebuchadnezzar's Avatar
There are a lot of reasons why a car will not start. Can you give us a little more information on what you've noticed in the past? Is it really hot or cold where you live?
I have seen and heard about ignition switches going bad and becoming sensitive to cold temperatures. When it's cold, it'll take several tries to get it to start. Even batteries that aren't producing enough CCAs will eventually start giving you weird problems like this. If you have the original battery, you're way overdue.
Old May 6, 2013 | 10:09 AM
CryptoStorm's Avatar
Also.. Your not really describing the situation fully..
By "doesn't start" do you mean:
A) you turn the key and nothing happens (no lights or sounds)
B) you turn the key and the dash lights come on but when you turn it to start nothing happens
C) you turn the key and the dadh lights come on but when you turn it to start it clicks or grinds
D) you turn the key and the dash lights come on but when you turn it to start it turns over but won't start
Old May 6, 2013 | 10:58 AM
the car willl turn over and turn over but doesnt seem to be getting a spark or fuel
Old May 6, 2013 | 11:00 AM
Normally doesnt start when its hot
Old May 6, 2013 | 01:31 PM
Fuel pump relay sounds like.. Getting weak.. Its under your dash
rgwilliams44
B7 Models
10
Dec 20, 2021 01:00 PM
rgwilliams44
B7 Models
Jul 1, 2013 05:19 PM
nkasco
Aug 25, 2011 04:12 PM
chippy
Feb 19, 2008 07:16 PM
tarvoa1
Nov 2, 2006 10:52 PM
