3 Small Problems
Old May 17, 2005 | 01:18 PM
aRIf's Avatar
Default 3 Small Problems
Hello Friends. I got three small problems. I hope you guys can help about them.
1-) Water Temp gauge sometimes work somethimes not. it works for 30 min then it drops 0°, then works again and goes to middle then drops again. Why?
2-) When I hit the break I feel pulse on the break pedal. Pulse comes only before I full stop. It is like ABS is on, but why? It happens after I got my new front bearing installed.
3-) My remote range is very short. I just replace the battries but still same. Range is about 10mt or less. Is there a way to make it longer?
Thanks for the answers...
Old May 17, 2005 | 01:22 PM
CRAZYHAWK's Avatar
Default RE: 3 Small Problems
Replace the temperature sensor.
Old May 17, 2005 | 01:24 PM
aRIf's Avatar
ORIGINAL: CRAZYHAWK
Where is it ? Where can I find it ? How much is it? sorry too much question
Old May 17, 2005 | 01:27 PM
david9999's Avatar
Welcome to the world of Audis. You have to be almost touching the car for the remote to work. Normal but a pain
Brakes, sound like perhaps a warped rotor, or something not seated right. Sorry, suspension and brakes are not my strong point. Any codes that could signal ABS problems?
Old May 17, 2005 | 01:36 PM
aRIf's Avatar
ORIGINAL: david9999
Nop ABS light is not on, so I think there is no code. and it does not doing it all the time.. just most of the time.
exp: I come from Hw to an exit, start to apply hard break until 30mpr then before come to stop sign, I apply soft break then I hear that sound.
Old May 17, 2005 | 03:27 PM
hb972.8q's Avatar
ORIGINAL: aRIf
ORIGINAL: david9999
is it just the sound or does it vibrate through the pedal. it does just sound like a warped rotor. if you wanted to you could cleen off your abs sensors see if that helps. they are on you brake calipers.
Old May 17, 2005 | 03:44 PM
aRIf's Avatar
it is both sound + pulse&vibrate on the break pedal.
is it easy to reach the abs sensor without taking the tire off ?
Old May 17, 2005 | 05:58 PM
BFlan2001's Avatar
1. coolant temp sensor. it's located on the rear side of your engine, just in front of the firewall....here's where you can buy them......and here's a write-up on how to do it yourself.
2. your abs speed sensor is either dead or incorrectly installed. if you've had any suspension work done recently, alot of times the mechanics will reinstall it wrong. if it's failed they are about 140 bucks to replace.
3. yes you can make the range longer. you have to relocate the antenna which is located under the rear seat bench. here's a simple write-up on how to do that...
Old May 17, 2005 | 06:00 PM
BFlan2001's Avatar
if it only happens just before coming to a complete stop then it is definitely your abs sensor, and no, it's not very easily accessible without removing the tire
Old May 17, 2005 | 06:22 PM
aRIf's Avatar
thank everbody
and thanks a lot bentframe. Great info.
