300hp 1.8t??
i was looking thru the forum and im going to get a 1.8t what do i need to get in the 300hp range? what will you brake? i just need to know what size turbo,injectors,maf,and other stuff to get. thanks for the help guys i have a cartech rise rate fpr left over from my turbo neon project.
RE: 300hp 1.8t??
GT2871RS from renn-art will get the job done the kit has everything you need for like $3400
RE: 300hp 1.8t??
it can be done, t3t4 will get u there. u will break something. engine, exhaust mani, just depends on ur car. injectors u will need 440 or 550cc depending on what the ecu is written for.
RE: 300hp 1.8t??
on the t3/t4 what ar's and trim will i need. what clutch will i need.
RE: 300hp 1.8t??
Jeff knows all the t3/t4 stuff but i think your gunna need probable a stage II or III clutch with that much power
RE: 300hp 1.8t??
u will need a stage 3 or 3+ to hold that power, and for ar's it depends on what kind of spool u want, tom has a stage 3 exhaust wheel i think and i have something simular
RE: 300hp 1.8t??
what if you have tiptronic?
RE: 300hp 1.8t??
With the tip your gunna want to have the level 10 kit which will run about $800 to handle that kinda hp
RE: 300hp 1.8t??
you can get an APr stg3 or 3+. for a more friendly price there are the ATP eliminators. Rennart sales them in a kit with injectors. MAf, everything you need.
RE: 300hp 1.8t??
ORIGINAL: BadLuckAudi GT2871RS from renn-art will get the job done the kit has everything you need for like $3400 Or the T3/T4 route, which will be cheaper, only problem is you will spend more time trying to get it tunned good since no software is specifically made for it. |
