440cc injectors
Old Aug 28, 2006 | 03:19 AM
b52000a4's Avatar
Default 440cc injectors
is it possible to run bigger injectors before getting new software? i have beeen asking these questions because i plan on upgrading my turbo and i am tryin to piece it together... i would hreatly appreciate any help given
Old Aug 28, 2006 | 03:55 AM
PandaXpress's Avatar
Default RE: 440cc injectors
no dont run larger injectors with out the turbo or programmin casue u will run rich
440cc u better be going GT28 or biggger
Old Aug 28, 2006 | 10:48 AM
dafrazi's Avatar
You can run bigger injectors but you would need to adjust the fuel pressure to match the larger injectors.
It's better to wait and install the whole turbo upgrade at once. If you are piecing the kit together, just leave the parts in the garage or your closet until your ready.
Old Aug 28, 2006 | 11:40 AM
tatman9999's Avatar
I have 310 red tops with a 3 bar fpr and giac ko4-15 pc-16 softwear.Your car will not run right with 440.You need diffrant turbo ,fpr,softwaer then injectors.
Old Aug 29, 2006 | 01:42 AM
b52000a4's Avatar
ok well then if im piecing it together can i get the turbo and put it on before i get injectors and software etc, if its not driven hard? i just ordered the atp manfiold and test pipe
Old Aug 29, 2006 | 01:45 AM
Bondga's Avatar
Putting the turbo on before the software will mess up you AF ratio but im not sure how. I think you'll run lean because the bigger turbo would push more air at the same boost level maybe not to sure.
Old Aug 29, 2006 | 01:47 AM
b52000a4's Avatar
could i not just turn the boost down for that? i guess i should be buying a boost gauge and a/f ratio soon?
Old Aug 29, 2006 | 01:48 AM
Bondga's Avatar
if you can control it what are u using to control teh boost ecu or MBC. minimum boost you can run is 6.5
Old Aug 29, 2006 | 02:16 AM
b52000a4's Avatar
a friend of mine is selling me his apexi super avc-r boost controller
Old Aug 29, 2006 | 02:21 AM
Bondga's Avatar
well as long as you dont need to boost lower than 6.5lbs to run stoich. just get a AF meter so you can see where your running and tune the boost so your at stoich. and your gonna need an AF meter if your gonna run a MBC anyways so might as well get one now. but if you can put it on and make sure you run stoich and a little rich while accelerating and you should be fine until you get the software
