5spd Problem?
Old Jun 23, 2005 | 02:53 AM
MadIce's Avatar
Default 5spd Problem?
97 Audi 2.8L A4. I noticed when in 1st gear I hear a chatter type noise. Once I'm in 2nd the noise stops (*it does not happen in any other gear including reverse). Is this the clutch or something else in the trans (I don't believe its engine related).
Old Jun 23, 2005 | 02:56 AM
BFlan2001's Avatar
Default RE: Quick 5spd Q
uh ooh...if it's a fairly loud clicking sound, that's not good....i had the same noise coming from my 12V, it was my first gear synchro...replacing the synchro basically means a tranny rebuild...i went with a used tranny cause it was cheaper. hope that's not your problem
Old Jun 23, 2005 | 02:58 AM
MadIce's Avatar
ORIGINAL: bentframe
Crap it is a pretty noticable noise... how much did the trans cost? []
Old Jun 23, 2005 | 03:21 AM
BFlan2001's Avatar
i ended up paying 4 grand after everything (labor, new driveshaft, + a few random little things)
www.car-part.com has a ton of 5-speed trannys for cheap, if you can find someone to install it for you
Old Jun 23, 2005 | 03:23 AM
BFlan2001's Avatar
get it checked out at a mechanic, but don't tell him anything about suspecting a synchro or tranny issue at all, let him diagnose it completely on his own.
Old Jun 23, 2005 | 03:25 AM
MadIce's Avatar
****! [:@]. I just bought this car two days ago for 6k and didn't notice the noise till driving today in the suburbs.
Old Jun 23, 2005 | 03:28 AM
BFlan2001's Avatar
LOL, you're in the same boat as me...exactly the same pretty much...except i heard the noise when i bought the car (i thought it was an exhaust issue [:@][:@][:@])
Old Jun 23, 2005 | 03:33 AM
MadIce's Avatar
ORIGINAL: bentframe
Ya at first I thought 6k for this car was really good since the timing belt, water pump, and other stuff has already been taken care of about 10k miles ago (car is at 96k). Now I'm pretty pissed and feel royaly ripped off that I have to put money into it
Old Jun 23, 2005 | 03:35 AM
BFlan2001's Avatar
it won't cost you four grand, if you do enough research and call enough shops, you can probably get it done for 2500, maybe even 2 grand...where are you located?
Old Jun 23, 2005 | 03:44 AM
apg96's Avatar
is it everytime ur in first or only some time?
