6 PSI?
Old May 29, 2007 | 01:38 PM
Mya4T's Avatar
Default 6 PSI?
car is completely stock but is it just me or is that a little low shouldnt it be at 8-9 PSI
Thinking a boost leak?
what do you think
Old May 29, 2007 | 02:10 PM
ironman's Avatar
Default RE: 6 PSI?
Check for boost leak anyway, and if you cant find any chip it and go mid teens, then it wont be alitel low any more
Old May 29, 2007 | 03:06 PM
kpatz's Avatar
Default RE: 6 PSI?
Could be a boost leak, or you're in limp mode due to overboost or running lean or something like that. Is your CEL on?
Another cause can be a clogged or failed N75 valve. I had my turbo replaced last week and only got 5-6 psi boost until I pulled my N75 and unclogged it. I'm chipped too.
Old May 29, 2007 | 05:57 PM
Mya4T's Avatar
Default RE: 6 PSI?
do 98s have n-75?
Old May 29, 2007 | 06:01 PM
TDRILL's Avatar
Default RE: 6 PSI?
What is it supposed to be?
I thought 6 psi was stock level and you don't go over that until after you chip it.
Old May 29, 2007 | 06:57 PM
Mya4T's Avatar
Default RE: 6 PSI?
i thought it was 8
Old May 29, 2007 | 07:35 PM
sdboarder84's Avatar
Default RE: 6 PSI?
it is 8-9 psi for 2000+ , before that 6-7 is normal pressure. They uped the boost in 2000 to help get to the 170hp as opposed the pre 2000 150hp
Old May 29, 2007 | 08:20 PM
TDRILL's Avatar
Default RE: 6 PSI?
Thats what I thought. But I think your years are off. I think only the 2001 has the higher boost and pre-01 is at 6-7 psi (not 00 as you stated).
http://ctny.audiworld.com/mark/a4/diff/
So since Mya has a 98, his boost should be good. Chip it and then you will prob be able to find a boost leak or two ;-)
Old May 30, 2007 | 12:34 AM
Aznpulse's Avatar
Member
Default RE: 6 PSI?
Yeah I was boosting around there on my car. But, the n75h vavle raised it up by 2-3psi. I didn't get much experience with it as I got my chip the next day. 15psi =/ I think it's leaking now.
