6-speed s4 tranny
I've been thinking for a while now how much more performace a 6-speed tranny is gonna give me if i swap it for my 5-speed. Is it going to affect 0-60 1/4 and top speed? Also what other parts would i need and how much can i get the cheapest 6-speed for. How much labor and stuff like that. Just an idea for now. If i do it it is going to be after a couple of months. Thanks guys.
3 ppl have done it that I know of,
Parts needed:
6 speed trans
linkage & stabilizer bars
center shaft
rear dif
left & right trans mounts & brackets(left one will need fabrication)
either A4 rear dif flanges, or S4 1/2 shafts
To eliminate the fabrication to the left trans mount, you could either install an S4 front subframe, or weld on a bracket to the A4 subframe to fit with the S4 left trans mount(which I intend to do soon - better IMO).
3" downpipe will require modification to the right trans mount bracket. Shifter area in the center console is a little tight for 4 gates, but does just fine.
Parts needed:
6 speed trans
center shaft
rear dif
