96 A4 water temp. light on??
Old Oct 30, 2007 | 11:52 AM
jonellebel's Avatar
Default 96 A4 water temp. light on??
I have a 96 A4, and the water temp. light goes on when I start the car, and then anytime I stop or take a turn. The temp. guage shows the temp is fine, so I ruled out the thermostat. Could this be the ECT sensor, or the coolant reservoir? Is there a level sensor in the reservoir, because it seems when the fluid moves, it goes off. If so, can just this sensor be replaced, or does the whole reservoir have to go? Thanks for any help you can offer!
Old Oct 30, 2007 | 11:56 AM
onepoint8tee's Avatar
Default RE: 96 A4 water temp. light on??
Is the fluid up to the full mark in the resevoir?
Old Oct 30, 2007 | 03:59 PM
Trey25's Avatar
Change the sensor, its the most common coolant problem. Luckily its the cheapest.
e@dyab
Jul 13, 2011 04:42 PM
toboater
Oct 26, 2010 12:15 PM
fireman9585
Aug 2, 2007 01:39 PM
haveaseat
May 23, 2006 11:54 PM
dbcq
Mar 22, 2006 01:15 AM
