96 audi A4 both back doors won't unlockPlease help !!
Old Jun 28, 2007 | 10:42 PM
needcomics's Avatar
Default 96 audi A4 both back doors won't unlockPlease help !!
I have a 1996 Audi A4door locks worked yesterday now both back doors won't unlock from the inside or outside. I tried open them by inside and outside door handles. I can't pullthe door **** locks up by force, even when I do the doors won't unlock and they go right back down. I need to get my kids in the back please help
Old Jun 28, 2007 | 11:16 PM
96audia4's Avatar
Default RE: 96 audi A4 both back doors won't unlockPlease help !!
The doors use a vacuum lock system, so pulling the button to the unlock position won't help. I'm pretty sure you should be able to open them from the inside though. You might want to check the vacuum hoses to make sure nothing is punctured.
Old Jun 29, 2007 | 12:24 AM
AteUrV8's Avatar
lol, this happened on my old audi, but only one of them stopped working... check the child locks, it could be as simple as that, its gotta be something simple... a door usually wont open because something is jammed or child locks are on or something easy... take it in, it should be an easy fix... dont jinx it tho lol
Old Jun 29, 2007 | 01:01 AM
needcomics's Avatar
where is it located ??? I triedopening from the inside and out still won't work
Old Jun 29, 2007 | 01:21 AM
c346123's Avatar
The child locks are on the side of the door and can be seen when you open it so it can't be that otherwise they would've opened from the outside so it has to be a vacuum hose that has been punctured.
Old Jun 29, 2007 | 01:37 AM
needcomics's Avatar
were isthe vacummhose or hoseslocated so I can check
Old Jun 29, 2007 | 03:00 AM
18T's Avatar
18T
check your child locks
Old Jun 29, 2007 | 09:29 AM
Black_97 A4's Avatar
You know all you guys are telling him to check child locks and things inside of the door, and im just thinking how are you going to do that when you can get the door open? might be kind of difficult to get the door panel off with the door locked because you cant open teh door...
Old Jun 29, 2007 | 11:08 AM
tfische12's Avatar
Thats weird. I had the same problem with one of my doors on my old 4000Q. I would pull off the interior door panel and see whats going on. You may have to take out the rear seat. It should be possible. That is what I had to do with my 4000Q. It’s not the vacuum system because it only operates to lock and unlock. So manually unlocking the door should work as long as the vacuum system is not constantly running in the lock mode. In which case the front doors would also be locked. If a leak did occur while the door was locked you would still be able to manual unlock the doors. You can try manual pulling up on the lock **** while trying to open the door (from inside and out) plus a good shoulder bump. Hope this helps some. If all else fails just keep the windows down and have your kids jump in dukes of hazzard style.
Old Jun 29, 2007 | 01:08 PM
mikehh's Avatar
Thats soo funny!
I had the same problem just with one side on my 96. NOTHING you can do, unless you rip apart your interiors. You can't get to anything without opening the door. I was soo frustrated with mine, but did NOT rip it all apart. I think after two weeks is just started working again and worked ever since. Just after it started working again, I took it all apart and gave it a good lube....
Good Luck!!
let us know if it comes back to life on you
