97 afc 2.8 questions
Old Jul 7, 2007 | 06:36 PM
bbaer6676's Avatar
Default 97 afc 2.8 questions
Well i pulled the front end because my fan clutch went up. then i figured while im in there....
I pulled the fuel rail and am replacing the injectors, then I pulled the TB and cleaned that up, then I pulled the intake to clean and put new gaskets in. Then I figured I might as well change the timing belt even though its only got 40k on it. (car has 225k, currentlong blockhas 80k (I bought it used after my head got damaged from a broken valve spring)) So my questions are,
1) Is there a aftermarket intake and exhaust for my 12v, my current exhaust seems to have a leak.
2) I was going to pull the heads and have them redone but I am worried that I wont be able to get the timing right, is there a tech article on setting timing after the heads have been r & r? I might just take the engine to the dealer and have them do it now that it is out of the car, labor will be alot less.
3) when I get the heads redone, is there a place I can get upgraded valve springs.
Thanks in advance, sorry for all the questions.
Brian
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
