98 A4 1.8T start up problem
Old Jun 18, 2006 | 08:55 PM
fatal02's Avatar
Default 98 A4 1.8T start up problem
Ok Friday I got off work headed to my car i started it up and threw me a CEL and started idling really roughly. I managed to make it to schucks where i VAG-COM'd it and it gave me code P0302 misfire cylinder #2. On saturday Redgoat came over and ran VAG-COM again and threw out the same codes, I went out and bought new NGK spark plugs BKR6EIX completed the installation fired up the car and still had the same outcome idling rough. I have also done some research and found that it could be my Coil Packs. So this morning (sunday) I decided to switch around the coil packs and see if my car would start rough once again and this time the car starts and turns but it will not fire up, smelled alot of gas and i even took out the spark plugs cleaned them and put everything back in place I am still stumped!!
Ric
Old Jun 18, 2006 | 09:30 PM
miked's Avatar
Default RE: 98 A4 1.8T start up problem
Could be a vac leak too. But plugs and coilpacks are what i would have suggested.
Old Jun 18, 2006 | 09:46 PM
Karl's Avatar
the code was Random Misfire on Cylinder 2.. does the random part make any difference? What hoses do you suggest he looks at first to check for a vac leak
and I wonder if he is even getting spark..?
Old Jun 19, 2006 | 04:19 AM
Karl's Avatar
come on anybody???
Old Jun 19, 2006 | 03:31 PM
fatal02's Avatar
I did some more testing it turns out my coils aren't shot and the connector on on cylinder 2 has no voltage??? Any cause of this? Spark plugs work all the coils work but when i connect the coil to #2 there's no voltage? Is it my ECU? or ICM?
Old Jun 20, 2006 | 01:46 AM
fatal02's Avatar
**UPDATE** I just went ahead and had the car towed to All European Autowerks in Kent wish her luck!!!
Old Jun 20, 2006 | 02:09 AM
Karl's Avatar
Bob wont have a problem figuring out what the problem is.. that guy is "The Man" when it comes to cars.. hope its nothing serious
Old Jun 20, 2006 | 07:55 AM
Session101's Avatar
i had a similar run in.
turns out it was the MAS Sensor at the top of the box, it was either clogged or the connectors were going bad.
so i basically cleaned it and the connectors too and pluged it back in and the car was running perfectly. took a
while for the check engine light to turn off, but that's what i did.
Old Jun 20, 2006 | 08:44 PM
fatal02's Avatar
ANOTHER UPDATE! Turns out it was my ICM!!!!!
Old Jun 20, 2006 | 10:40 PM
Karl's Avatar
how much is that going to run you to get fixed?
