99 2.8 quattro rear differential install
Old Sep 26, 2007 | 11:57 PM
czardini's Avatar
Default 99 2.8 quattro rear differential install
hey guys, ive just picked up a 99 audi a4 2.8 quattro off a friends dad for cheap...(i wasnt going to but i found the rear diff. on ebay with 40kmi for $350) so the rear differential locked up and needs replaced...
my questions are these:
1) the car i purchased is manual, the differential is off an 02auto, it looks exactly the same underneath, but id feel better if someone assured me this is true
2) when installing diff., anything i should look out for(a common problem?)
thanks and God Bless
Old Sep 27, 2007 | 12:22 AM
Redrum1's Avatar
Default RE: 99 2.8 quattro rear differential install
The biggest thing I would say is to make sure that the final drive gear ratio is the same from a manual and an automatic differential. I would think most everything else should be the same.
Old Sep 27, 2007 | 03:08 AM
czardini's Avatar
ORIGINAL: Redrum1
right,...the newer differential is off a 2001 passat with 4motion(auto)...i searched consumer guide and couldnt find the gear ratios
Old Sep 27, 2007 | 07:47 PM
czardini's Avatar
Manual
3.500:1 -1
1.944:1 -2
1.300:1 -3
0.943:1 -4
0.789:1 -5
3.444:1 -reverse
3.889:1 -final gear
so i found the gear ratios for a stock 99 a4 2.8 quattro, but cannot find the ratios for a 01 passat 2.8 4motion-AUTOMATIC...any help?
also, even if the gears dont match completely, itll just be geared, minorly, different, right?
ECS Tuning
Apr 6, 2015 02:55 PM
ECS Tuning
Mar 9, 2015 04:02 PM
ECS Tuning
S4
Mar 9, 2015 03:57 PM
ECS Tuning
Sep 25, 2014 03:16 PM
ECS Tuning
Sep 24, 2014 04:23 PM
