99.5 maint. and repairs, what else should i do?
here is the list that was written from the previous owner of everything he did to the a4 i bought from him. Sorta long so bare with me.
Miles.....Repair Done..... 38,755 Oil Change/tire rotation 41,572 Oil Change/new front right tire 46,265 Oil Change/tire rotation and fuel system cleaned 47,537Replaced power output stage, replace sparkplugs, replaced cam adjuster seal & valve cover gasket, checked brakes 48,795 replace passenger side right side seat airbag 49,062 replace battery 49,802 OilChange 51,082 Replace right rear tire 53,307Replace leftfront and rear tire, replace all brakes and new rotors,4 wheel alignment,replace outer tierod ends, replace serpentine belt,oil change 57,191Oil change/tire rotation 57,666 replace oil cooler lines 60171 repair key fobs(reprogramed) 61,263 Replace clutch 62,274Oil change 63,426 repair tire( hole in tire) 67,251 Oil change/tire rotation 70,046 drain/refill brake system, replace left and right rear axle seals, recall-inspect lower control arms and timing belt 70,116 Oil Change 73,450 Oil change 80,225 Oil change 83,960 replac vacuum valve 84,025 Oil change Now that the list is done is there anytthing you see that i should get done relativly soon. tomarrow im switching to OEM large filter, full syn oil(most likely Mobil 1 5w-30, live in ohio so i assume that should be fine), replacing the cabin and intake filter, possibly fuel filter depending on how much all this will be. At the same time i will be checking coolant, brake fluid as well. Let me know what you guys think, the car currently has i believe like 87,500 on it and again its a 99.5 1.8t quattro 5 speed manual. Thanks for any advice you may be able to give. |
RE: 99.5 maint. and repairs, what else should i do?
start on the underside with some finnegans wax oil under seal that will add life to it and prevent excess rusting and dont forget to grease up all the break pipes
Don't see timing belt, water pump and thermostat. That is one of the most important. If it hasn't been done, hurry up and get it done now or that belt will go at anytime.
i assumed the Tbelt as well. It didnt not say replace, but just said recall-inspect tbelt. my question was that pulley which one is it that needs replaced? cause he replaced the cam adjuster so was wondering if that was it
No, I don't think he'd have replaced the pully that is notorious for failing. Just buy a timing belt kit and waterpump (plus G12 coolant) and get that changed asap.
ecstuning.com sells an 'ultimate' kit which has everything. Mobil 1 0w40 is what is recommended by Audi. Castrol Syntec 5w40 is what the dealer uses. |
I just did the oil change and replaced the air filter went with the stock large filter, mobil 1 5w-30 full synthetic and a purolator air filter(didnt have money for a good one), quite glad i did saw that he had used some cheapy oil filter, i was amazed by the size difference. By the way found out it was cheaper getting the same filter from a VW dealer than Audi, incase it might help someone else. Also saw wha tlooked like power steering fluid(red tint to it). coming from the front passenger side of the motor, it had leaked down and was on the plastic that proctected the motor underneath. What you think could that be leaking? i plan next week to do the timing, waterpump and pulley(which pulley exactly do i need). i just want to get all of the potential hazards out of the way asap as the money comes in. Thanks for the help ladies and gents.
Just get a full t-belt kit, it usually includes the belt, tensioner, tensioner roller, water pump impellar, themostat, and 3 other drive belts. usually around 250-300 bucks for the kit.
Use Mobile 1 0w-40 next time, same filter. Was the leak far enough back to be the tranny? If not, then you have a coolant leak somwhere.....maybe the line going to the turbo, thats where it is. There's a bunch of us in ohio....check this out...... https://www.audiforums.com/m_354383/.../tm.htm#354383 |
Double post.......oops
Hey i have a 2001 A4 1.8t 62k on it when do you usually change the tbelt on it and everythng else?
Thanks |
