99.5 maint. and repairs, what else should i do?
here is the list that was written from the previous owner of everything he did to the a4 i bought from him. Sorta long so bare with me.
Miles.....Repair Done.....
38,755 Oil Change/tire rotation
41,572 Oil Change/new front right tire
46,265 Oil Change/tire rotation and fuel system cleaned
47,537Replaced power output stage, replace sparkplugs, replaced cam adjuster seal & valve cover gasket, checked brakes
48,795 replace passenger side right side seat airbag
49,062 replace battery
49,802 OilChange
51,082 Replace right rear tire
53,307Replace leftfront and rear tire, replace all brakes and new rotors,4 wheel alignment,replace outer tierod ends, replace serpentine belt,oil change
57,191Oil change/tire rotation
57,666 replace oil cooler lines
60171 repair key fobs(reprogramed)
61,263 Replace clutch
62,274Oil change
63,426 repair tire( hole in tire)
67,251 Oil change/tire rotation
70,046 drain/refill brake system, replace left and right rear axle seals, recall-inspect lower control arms and timing belt
70,116 Oil Change
73,450 Oil change
80,225 Oil change
83,960 replac vacuum valve
84,025 Oil change
Now that the list is done is there anytthing you see that i should get done relativly soon. tomarrow im switching to OEM large filter, full syn oil(most likely Mobil 1 5w-30, live in ohio so i assume that should be fine), replacing the cabin and intake filter, possibly fuel filter depending on how much all this will be. At the same time i will be checking coolant, brake fluid as well. Let me know what you guys think, the car currently has i believe like 87,500 on it and again its a 99.5 1.8t quattro 5 speed manual. Thanks for any advice you may be able to give.
49,802 OilChange
62,274Oil change
70,116 Oil Change
73,450 Oil change
80,225 Oil change
84,025 Oil change
Don't see timing belt, water pump and thermostat. That is one of the most important. If it hasn't been done, hurry up and get it done now or that belt will go at anytime.
i assumed the Tbelt as well. It didnt not say replace, but just said recall-inspect tbelt. my question was that pulley which one is it that needs replaced? cause he replaced the cam adjuster so was wondering if that was it
No, I don't think he'd have replaced the pully that is notorious for failing. Just buy a timing belt kit and waterpump (plus G12 coolant) and get that changed asap.
ecstuning.com sells an 'ultimate' kit which has everything.
Mobil 1 0w40 is what is recommended by Audi. Castrol Syntec 5w40 is what the dealer uses.
I just did the oil change and replaced the air filter went with the stock large filter, mobil 1 5w-30 full synthetic and a purolator air filter(didnt have money for a good one), quite glad i did saw that he had used some cheapy oil filter, i was amazed by the size difference. By the way found out it was cheaper getting the same filter from a VW dealer than Audi, incase it might help someone else. Also saw wha tlooked like power steering fluid(red tint to it). coming from the front passenger side of the motor, it had leaked down and was on the plastic that proctected the motor underneath. What you think could that be leaking? i plan next week to do the timing, waterpump and pulley(which pulley exactly do i need). i just want to get all of the potential hazards out of the way asap as the money comes in. Thanks for the help ladies and gents.
Just get a full t-belt kit, it usually includes the belt, tensioner, tensioner roller, water pump impellar, themostat, and 3 other drive belts. usually around 250-300 bucks for the kit.
Use Mobile 1 0w-40 next time, same filter.
Was the leak far enough back to be the tranny? If not, then you have a coolant leak somwhere.....maybe the line going to the turbo, thats where it is.
There's a bunch of us in ohio....check this out......
https://www.audiforums.com/m_354383/.../tm.htm#354383
