99 a4 burning lots of oil
Old Apr 1, 2013 | 04:31 AM
Expplucky's Avatar
Default 99 a4 burning lots of oil
99 audi a4 2.8, 30v
no leaks, car is burning a lot of oil after two months it burned down to only 2quarts almost killed my car because i didnt check.
Any ideas? im about to try an adative and maybe changing the piston rings if anyone knows of a good dyi for it.
Old Apr 1, 2013 | 02:56 PM
ECS Tuning's Avatar
Sponsor
Unfortunately if its not leaking it and only burning it it's probably rings. I would do a compression test and or a leak down test.
Jason
Old Apr 1, 2013 | 08:46 PM
Expplucky's Avatar
Is it possible to change the rings without removing the engine block?
Old Apr 2, 2013 | 10:51 AM
ECS Tuning's Avatar
Sponsor
I suppose but I wouldn't just because you practically need to pull the engine anyways, and having the engine out makes it much easier to hone if you do it yourself.
Jason
Old Apr 2, 2013 | 10:37 PM
Expplucky's Avatar
UPDATE: ok so i did the compression test
cyl#
1-120
2-130
3-145
4-120
5-140
6-130
Added rislone additive in with the oil yesterday.
But today i'm noticing really rough idle and a really slow response when i accelerate, and when i floor it, it makes a chocking sound,
my mafs been un-plugged for like a year, and ive cleared the 02 codes.
also my coil pack and spark plugs and spark plug wires are all good.
air filter is clean and throttle body is aswell (didnt pull the throttle body off to clean it just used cleaner and a tooth brush)
ANY IDEAS?
also i notices on the right head there is oil on top of the head and outside the cover from what looks like a spill (probably the a hole who changed my oil! NEVER GO TO PEP BOYS)
Old Apr 3, 2013 | 03:02 AM
redline380's Avatar
Legal Moderator
are you sure youre not leaking oil? look closely. if it were burning that much youd see smoke most likely. common leaks would be valve cover gaskets, cam chain tensioner gaskets, oil cooler, pan gaskets, maybe even the oil plug
Old Apr 3, 2013 | 10:25 AM
ECS Tuning's Avatar
Sponsor
Why is your MAF unplugged? It should always be plugged in. Running it this way for a long period of time could cause damage...
Jason
Old Apr 3, 2013 | 01:19 PM
Expplucky's Avatar
Jason
Well its been unplugged because its dead. All the new ones I've bought don't work. I got two used ones and a no name brand new one that didn't work. The used ones worked for a while.
Old Apr 3, 2013 | 01:21 PM
Expplucky's Avatar
I don't see any spots on my drive way. But would a leak cause all the problems tbat I mentioned in my update?
Old Apr 4, 2013 | 03:45 AM
Expplucky's Avatar
Default Update
UPDATE:
-changed fuel filt
-changed plugs and gaped thim @32
-noticed a hole in the exhaust so I jb welded it
-checked fuel injectors and they are all clean. Really clean anlmost not gunk at all.
Now I'm just waiting for the jb weld to dry and well see if it fixed it. If not I'm guna throw some seafoam into the tank.
