a4 1.8t misfire problem!
Old Mar 28, 2005 | 11:52 AM
markupton's Avatar
Default a4 1.8t misfire problem!
Hi everyone,
After returning to my '97 1.8t after 6 weeks my car has developed a misfire. This happens at 300rpm and at 5200rpm although not as bad. It feels as though I am hitting a rev limiter, the rpm drops down to 2500 and then rises again. Above and below this all is fine although the car definitely feels low on power. It makes no difference whether I am driving or in neutral the same happens.
I added stp injection cleaner to the fuel but it made no difference.
Does anyone have any ideas? Thanks
Old Mar 28, 2005 | 12:12 PM
Jestnomen's Avatar
6th Gear
Default RE: a4 1.8t misfire problem!
have you run througy a complete tank of gas yet? How many miles has it been since you've been back driving it?
Old Mar 28, 2005 | 12:17 PM
TGPorsche96's Avatar
You might want to check the seals also...usually liquads start to get gunky after sitting there...its like mcdonalds and our arteries..lol
Old Mar 28, 2005 | 12:20 PM
markupton's Avatar
no, only about 90 miles and 1/4 tank
Old Mar 28, 2005 | 12:40 PM
Jestnomen's Avatar
6th Gear
Well use up the last of that gas and fill it with premium and see if that helps. Maybe some condensation in the tank?
Old Mar 28, 2005 | 01:23 PM
markupton's Avatar
ok thanks, will let you know if it works.
Old Mar 28, 2005 | 02:31 PM
Skibos's Avatar
id drain the gas tank and then put in 93 if that doesnt work then i would go to audi dealer..... sorry bro
Old Mar 28, 2005 | 05:01 PM
headshok2002's Avatar
I had the exact same sensation with my Talon... and I changed plugs and wires -- and all was well in the world again (as well as it could be for a DSM). But yeah, the rev limiter sensation is what made me think of it... low on power, and then it just wouldnt go past 5000 RPM. Dont think sitting there would soil your plugs or wires though... who knows, if you havent changed plugs/wires recently, do it anyhow :P
Old Mar 29, 2005 | 01:58 PM
skidplatexa4's Avatar
Yo I had the same type of problem last week. two of my coil packs went bad so I replaced em all and did the plugs it cost me like 500 bucks. Also the output stage on those things are known to go bad the audi dealer told me. Good luck man
skidplate
shongill
S4
Aug 13, 2013 03:37 PM
CYLax
Jun 30, 2010 07:19 PM
Nags
Jun 24, 2010 04:37 PM
mrbloink
Jun 12, 2009 04:42 PM
a4Fan1.8t
Oct 17, 2007 05:34 PM
