A4 2.8 timing belt
THere is alot of fuss around the timing belt problems with 1.8T uear of 98, wut about a 98 2.8 Q do they have the same problems, does a timing belt have to be changed too, and when you say timingt belt, is it the whole new assembly has to be cnanged or just the belt itself, THanks alot guys
P.S. on which models is the timing belt problem, only 1.8T or on 2.8 too and wut year
CHEERs
CHEERs
All timing belts/tensioners have to be replaced, as if they snap or the belt skips a tooth, your engine is toast in 2 seconds.
Yes, you should change all the components while you are in there. the major cost is to access the parts, not the parts themselves. Water pump is about 40 to 50 dollars, but labor to access it is 300. Might as well replace it while you are there rather than having to fix it in 6 months..
but what if i dont change my tensioners, just change my timing belt like every 45k and check tensioneers for skippin often, can i get away without changing them and if i see taht the yare skippin only then change them. in other words will my engine get fried if a tensioner will skip.;
thanks
thanks
No you cannot.
You don't get a second chance. Once the belt breaks, or skips because the tensioner failed, you are looking at several thousand dollars for a valve job.
Of course, if you want to play it safe, trade your Audi for a Toyota which has a non-interference engine.
There is no reason to not change everything while your in there. You make it sound like you want to just slip a new belt on there quickly and be done. It is an involved process and changing the tensioner and idle pully only add a small amount of time.
alright thanks for eveythin but if i get a car that has 80 k on it, how do i know if it has been changed and also, when si it reccomended to change the belt? because i read the manual is 90k but most ppl say 60
Cheers
Cheers
There really isnt too good of a way to tell. I stuck my head in there and could see the accessory belt was looking cracked and frail. Also some people say if the writing on the belt is faded away, its time to change. Where did you buy it from? Maybe there are some service records at Audi. Audi recommends changing at something like 110k, but thats way too late. Most people say between 60-70. Better safe than sorry!
Audiguruforyou
Sep 20, 2011 01:31 AM
Jeffla
Jan 3, 2010 04:43 AM
fritz
Aug 12, 2007 02:55 PM
