A4 B6 HID Light Bulb Replacement HELP!!
Old Nov 23, 2007 | 03:33 PM
a4ultra's Avatar
Default A4 B6 HID Light Bulb Replacement HELP!!
I need help on how to remove my old hid bulbs from my b6 a4 audi and installing new ones. Please Help!!
Old Nov 23, 2007 | 04:00 PM
ocadam's Avatar
Default RE: A4 B6 HID Light Bulb Replacement HELP!!
There is plastic caps on the back of the headlight. Snap those off and pull those suckers out.
Old Nov 23, 2007 | 04:29 PM
a4ultra's Avatar
yea, but i can't get to those covers because there's a steering fluid resivoir in the way
Old Nov 23, 2007 | 10:46 PM
jflores72's Avatar
Do a search on removing lights, I found it very easy to do when I had to change my front turn signals. You need to remove certain things on topand then remove your entire light housing which are connected by four screws. Thetwo screwson top which are visible you completely remove them and the other two which are at the back you just have to unsrew them about two turns but do not remove them and then all you do is unplug connections and pull the light housing out.........It is very easy.......
[IMG]local://upfiles/44391/791FCB621B684905B7B3459505DEA4A0.jpg[/IMG]
[IMG]local://upfiles/44391/3177E00BF96D4F1AA914E96D8C2F82BF.jpg[/IMG]
[IMG]local://upfiles/44391/8B6306AA5A82477784CC8AFB1C3F299E.jpg[/IMG]
Old Nov 23, 2007 | 10:52 PM
jflores72's Avatar
As a matter of fact, here is the link for removing your headlight housing.........
www.audidiy.com
this is is very informative and will even show your pic's on what to look at............
[IMG]local://upfiles/44391/F930325232F94138AD5BAA750D887B5F.jpg[/IMG]
[IMG]local://upfiles/44391/A8D9BA304F0748C3AAA10B2C680B5467.jpg[/IMG]
Old Nov 23, 2007 | 11:14 PM
jflores72's Avatar
Just trying to be a little more helpful to you, here is the actual instructions with pics.........
http://www.audi-forums.com/attachmen...front-rear.pdf
Like I said before it is very simple to do, just take your time and make sure you be careful taking off the back cover of the HID, because I have heard you can shocked if your not careful.........
[IMG]local://upfiles/44391/C3E0E9B9BF6644208AE434C83CDAEA54.jpg[/IMG]
[IMG]local://upfiles/44391/18C31BE67F0448D495495FA0A3701775.jpg[/IMG]
[IMG]local://upfiles/44391/647D62D292094A189E3A0E3815F366A1.jpg[/IMG]
[IMG]local://upfiles/44391/24493C0CF23E4A80B6AFCD1D7A6B3CE6.jpg[/IMG]
Old Nov 23, 2007 | 11:17 PM
jflores72's Avatar
Here you go, first one copied wrong
knerml
B7 Models
Mar 4, 2009 12:24 PM
Peoples-2
Dec 14, 2008 10:44 AM
tsk
Apr 27, 2008 04:56 PM
calin07
Feb 7, 2007 03:12 PM
yadude
Nov 8, 2005 12:07 AM
