A4 diesel starting problem
Old Feb 10, 2007 | 01:11 PM
dleamy's Avatar
Default A4 diesel starting problem
[align=left]hi just wonderin could i pick someones brains my car seems to struggle on startup even when the engine is warm tested the heater plugs there fine, and i changed the temp sensor switch and still no difference the car runs perfectly when started any ideas?
[/align]
Old Feb 10, 2007 | 09:05 PM
mikehh's Avatar
Default RE: A4 diesel starting problem
have you checked the fuel pressure? I'm thinking of a clogged filter?
Old Feb 10, 2007 | 11:36 PM
cstarky15's Avatar
where you from? the U.S.? i dont think they have diesel audis in the US so if you are in the us and putting diesel in your car you might have a huge problem.
Old Feb 11, 2007 | 02:55 AM
mikehh's Avatar
people in theUS are really missing out by not having diesel audi!!! Diesel is the ultimate!!!
Old Feb 11, 2007 | 11:39 AM
david9999's Avatar
The Audi Diesel hasn't been imported since the 5000.
I'd suggest trying the VW sites as the TDI was imported stateside and they have much more experience with diese
Old Feb 11, 2007 | 12:32 PM
techbod's Avatar
4main areas for hard start on a diesel
1 - glow plugs
2 - fuel filter
3 - air in system
4 - fuel pump timing
im going for 1 and 3 in your case because it runs ok when started
Smokin Tubes
Feb 5, 2012 10:11 AM
RKOOOO
Aug 13, 2011 07:37 PM
lojiuk
Nov 20, 2010 12:07 PM
bigjohn
May 9, 2009 11:52 AM
furh3r88
Feb 2, 2009 04:52 PM
